H Power Cyclone Avenger
117 replies to this topic
#26 Pablo
  • 18,486 posts
Posted 16 September 2011 - 07:29 PM
Thanks guys :D
The drivetrain sounds very noisy, I may try breaking them in with toothpaste or something ?
Next up is body paint and track test in a couple weeks.....
#27 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 16 September 2011 - 07:36 PM
I've had good success using graphite powder, that locksmiths use to lubricate lock tumblers.
You should be able to get some from your local locksmith.
Steve King
#28 Mike Patterson
  • 2,586 posts
Posted 16 September 2011 - 08:36 PM
Pablo,
Did you treat those gears to a ride in your tumbler? That would probably help your noise problem, and it's not as messy as toothpaste.
What color are you going to paint it? IIRC, mine was a medium-dark green with a chrome tape stripe (offset), and three circular number stickers.
#29 Pablo
  • 18,486 posts
Posted 16 September 2011 - 10:36 PM
Thanks for the tip, Steve K.
Mike, I doubt my ceramic media pieces would fit in between the teeth :laugh2:
Color will be Tamiya Purple with a white stripe.
#30 Kim Lander
Kim Lander
  • 604 posts
Posted 17 September 2011 - 09:05 AM
beautifl work Pablo...brings back good memories...by the way...are you going to be able to make The Viper Pit this coming weekend?....Kim
#31 Pablo
  • 18,486 posts
Posted 17 September 2011 - 12:49 PM
Rob, I can't find the brass nuts at PM website any more...did you buy them all ? :laugh2:
They were sweet while they lasted. I have about 4 left.
Hi Kim :bye: Thanks.
No GRRR for me on the 24th weekend, I'll be in Mexico looking for Bluefin tuna :big_boss:
Boarding a big boat in San Diego in search of school tuna. I hope to "school" some of them, or at least, rip some lips off :lol:
#32 TSR
Posted 17 September 2011 - 01:34 PM
Quote
Absolutely and make sure that it contains fluoride, so that the teeth get no cavities. :D
#33 tonyp
  • 15,325 posts
Posted 17 September 2011 - 02:39 PM
That thing should be pretty out of control with that motor in it.
#34 Pablo
  • 18,486 posts
Posted 17 September 2011 - 07:50 PM
Hopefully in a good, smooth way :D
#35 JohnnySlotcar
JohnnySlotcar
  • 2,036 posts
Posted 17 September 2011 - 08:25 PM
Rob, I have plenty of those narrow 5-40 nuts!
John Austin
#36 Mopar Rob
Mopar Rob
    Retro Snob as of 1/12/2011
  • 3,445 posts
Posted 17 September 2011 - 09:02 PM
Thanks John, I'm good for now. I'll post some photos of the F1 build I'm doing tomorrow. After a race I'm doing in October I'm going to do a 13D powered Sheraton Thomson Indy Car. I might need some then.
Maybe I'll come up tomorrow and try running the R-Geo prototype at Wanker Valley?
Rob Hanson
Cheater on 19 August 2010 said
Rob was right!
#37 Alchemist
  • 2,724 posts
Posted 17 September 2011 - 10:45 PM
The car is looking pretty jazzy and can't wait for the performance report !!! What color have you decided please?
#38 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 18 September 2011 - 02:51 AM
Steve King
#39 tonyp
  • 15,325 posts
Posted 18 September 2011 - 06:57 AM
Pablo, that much power in that Chassis is going to be a monster and fun to drive. All very good....
#40 dc-65x
  • 7,043 posts
Posted 20 September 2011 - 11:59 AM
Hi Pablo,
I really like your body mount solution. ;) Hind sight is 20-20 and that's the way I'd have done it....if I had thought of it! :laugh2:
As for your rough gear mesh, I've noticed that not all 48P gears are "created equal" and mesh smoothly, especially if both gears are metal. I'm lucky enough to have a variety of different pinions which helps in finding a combination that's "happy" with each other.
A Cox Nylatron spur gear would probably be an instant fix. Would you like me to see if I have one for the project?
Onward Pablo!
Rick
#41 Jairus
  • 10,174 posts
Posted 20 September 2011 - 12:09 PM
I like the Riggen wheels with that! :wub:
#42 Pablo
  • 18,486 posts
Posted 20 September 2011 - 12:10 PM
Thanks Rick, that well may be the problem - gears are similar but not mated perfect. I can't find any reason why the mesh should not be smooth - feels smooth when turned by hand, but when revs increase on power supply, it sounds nasty.
I think you are also right, a nylatron would be the ticket. Since my motor mount method is kind of permanent, it would have to mike about .987 ...... I would appreciate it !!!!! :D
#43 dc-65x
  • 7,043 posts
Posted 20 September 2011 - 08:51 PM
OK Pablo, here's what I've got. The Cox set screw hub spur gears measure about .275" wide. The 48T measures 1.045" in diameter. The 46T measures 1.008". A 45T might be just the ticket for your .987" number...but you'd have to get one from EJ's. He has them listed in his latest catalog.
If you could measure the distance over your armature shaft and axle I could use the measurement to mock something up. Then I might be able to find a combination of pinion and spur that would work.
If you had a bit of armature shaft sticking out past the pinion this would be pretty simple...but it looks like you don't :unsure: .
What do you think Pablo?
#44 Pablo
  • 18,486 posts
Posted 20 September 2011 - 10:14 PM
I'm at work tonight.
Let me check it tomorrow, then I'll get back to ya, OK Capt ?
With your help, I can fix this. :D THANKS RICK !
#45 dc-65x
  • 7,043 posts
Posted 20 September 2011 - 10:34 PM
"I'm witchu" my friend :D
#46 Pablo
  • 18,486 posts
Posted 21 September 2011 - 11:56 AM
OK here is the deal,
#1, thanks dc-65x for teaching me that not all gears advertised as "48 Pitch" will mesh well together. That was a learning experience for me.
#2, I think either a 46T or a 45T Cox nylon spur gear will mate better with my 16T 48P mystery pinion. Thanks everybody for understanding it would be painful to move the motor.
Hindsight is 20/20 and had I known a set of 48 pitch gears would not cooperate, I would not have secured the motor until I got a good mesh. My next build, I will be wiser....
#3, Rick, my best guess is, a 45T Cox is going to fit perfect. You said EJ'S Hobbies had them , BUT, they have a $40 minimum order. I found a Slotblog buddy who has both a 45 and a 46 who offered to send me both of them.
Thanks, Rick, for identifying my gear problem. :D
Thank you, Switchblade, for your generosity.
Thanks everybody for your support, without it, there would be no "Pablo" :o
Now I must pack for a trip to Mexico :D
#47 Pablo
  • 18,486 posts
Posted 29 September 2011 - 12:20 AM
Sure enough, dc-65x hit the nail on the head.....with a Cox spur, the drivetrain is smooth and really wails on the power supply !!! :D
Thanks again to Gary Stelter for supplying the perfect gear ! :friends:
Problem solved, thanks to my friends ! :yahoo:
Now, where is that doggone airbrush ?
#48 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 29 September 2011 - 06:30 PM
This is gonna be a good one! Can't wait to see the paint work. :wizard:
Gary Stelter
#49 Pablo
  • 18,486 posts
Posted 08 October 2011 - 09:22 PM
Track test #1 completed.
As I thought, the car runs very well overall. Handling is surprizingly good, it tracks and slides well, no bad de-slotting habits. Negotiates the sharp curves at Greg Gilbert's tight Gerding very nice ! :D
Speed and power delivery is excellent, it really scoots nice ! Very good acceleration and straightaway speed.
Drop arm/flag/front wheel relationship was perfect; fronts lightly touch and roll.
One problem: the car "hops" or "shudders" a little under acceleration.
So, I need to disassemble the drivetrain and trouble shoot that.
Paint coming soon; I have Model Master Acylics Deep Pearlescent Purple # 4651, and Grape Pearl, 4650.
We had the "Cruisin' the Coast" vintage car shows this weekend down here; lots of nice cars from the 30's to the 80's driving around. One thing I noticed is, alot of very nice cars were RUINED, in my opinion, by bad shades of paint. I saw a 30's hot rod painted baby blue, but it was FLAT looking, and the wrong shade. The baby blue that Merriman puts on his retro cars would have looked great on this car, but this thing looked like baby-puke blue.
On the other hand, I saw a 40's coupe that had very deep metallic purple, that is what I (we ;) ) want on this car.
Must do a test body first to make sure it's right. With acrylics, one never really knows how the paint will look until it's backed up with white or silver.
#50 Jairus
  • 10,174 posts
Posted 08 October 2011 - 09:40 PM
Just a guess, but I think the tires are providing too much traction. Let them dry out a week or two and give it another test if possible.
