How to build slot car tracks
405 replies to this topic
#276 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 28 May 2020 - 09:50 PM
That looks good, makes a nice connection and you still have portability. I used to just fold the tails over and staple them together underneath. But then you have to take the staples out to get the track apart. What I do now is put a dab of silicone in the slot that the braids run through the joint in. Then let it dry completely. Because the braids are touching together already, the silicone makes a pressure point to ensure a good connection. Then the braids are individually stapled to their corresponding track section. In this way I can take the track apart without disturbing the braid at all. In the morning the first thing I will do will be to silicone all the joints, then with the track in the basement while the silicone is drying I will wire the track.
I used this method for commercial tracks too but since most of those tracks would stay in the same place for a few years I also stapled the braid together underneath. And taps were made by crimping eye connectors to the braid tails and the tap wire and screwing them together to the bottom of the joint block. In some cases I left the tails long enough to go to a board with individual bolts for each tap. Just depended on how elaborate the wiring was going to be. For this little track the control system is fairly elaborate but the wiring to the track is going to be fairly basic. The runs in front of the drivers will connect a positive for each lane and I put some braid drops on the over bridge section for an additional negative tap.
  • Rob Voska and William Bowden like this
#277 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 30 May 2020 - 05:14 PM
Yesterday I put the silicone in the joints. Had some brown coloured GE stuff laying around, makes it easier to see
The dead strip area before cleaning up and stapling everything down. This mdf is terrible for spalling
The relay board glued in place
I forgot to take some stills of the finished wiring, I wasted a lot of time driving back and forth to the track today from my place. I will take more pics tomorrow. Everything is now wired except the negative tap, the braid ends are stapled to the joints and the track is now all down in the basement
I was a little optimistic when I brought a car and controller over this morning
But it will get used tomorrow..
  • Pappy, slotbaker, Rob Voska and 2 others like this
#278 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 30 May 2020 - 10:38 PM
(5) Steve Ogilvie builds a Slot car track- Relay board on the track - YouTube
  • Zippity, Rob Voska and William Bowden like this
#279 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 30 May 2020 - 10:56 PM
(5) Steve Ogilvie Builds a Slot Car track- Almost there - YouTube
#280 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 31 May 2020 - 06:53 PM
A few more wiring shots:
Deadstrip soldered up and wired. This is the way we did it for the old Autotrack system, I may have to change it for the Trackmate I have coming
Track is now bolted back together again and it runs on high and low power and everything worked well first time out. I found a variety of lane markers and managed to get these on the panel        IMG_3264.jpg
These peel and stick's are probably 10 years old so I needed a hair dryer to get the paper off but they look OK. We played around on the track for an hour or so and I brought out my slot car box for the first time in forever
Hi Joe always liked his box sticker. Post some video's later
  • Pappy, slotbaker, Eddie Fleming and 3 others like this
#281 MattD
MattD
  • 3,561 posts
Posted 31 May 2020 - 07:26 PM
Great job Steve, but the the sticker is better.
  • Steve Ogilvie and Tomark like this
#282 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 31 May 2020 - 10:34 PM
(7) Steve Ogilvie Built a Slot Car Track- It runs - YouTube
  • slotbaker, Zippity, Eddie Fleming and 2 others like this
#283 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 31 May 2020 - 10:37 PM
(7) Steve Ogilvie Builds a Slot Car Track-back together - YouTube
  • slotbaker, Zippity, Eddie Fleming and 1 other like this
#284 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 01 June 2020 - 09:22 PM
Got the walls mostly painted.Some finishing with a brush still needs to be done under the bridge but other than the stripes the track is done. I enjoyed this build and hope it helps people with their own tracks.
  • Pappy, slotbaker, Zippity and 9 others like this
#285 MattD
MattD
  • 3,561 posts
Posted 01 June 2020 - 10:18 PM
Steve, great tutorial.
  • Steve Ogilvie and William Bowden like this
#286 Gak
Gak
  • 13 posts
Posted 02 June 2020 - 12:25 AM
This thread has been a huge help to me Steve, especially as a newcomer to Routed tracks.
If there's a place to send donations, i'll forward you on some beer tokens  :good:
Thanks again & its never to late to write that book!
Best regards
Graham
  • William Bowden likes this
Graham Bowden
#287 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 02 June 2020 - 07:23 AM
Thanks for all the comments and likes and feel free to ask questions. I usually check slotblog every day except when we are on holidays.
#288 Eddie Fleming
  • 2,944 posts
Posted 02 June 2020 - 08:11 AM
Thank you Steve for the great how to thread. That's a great home track.
I have never built a track but you have me thinking about what will fit in my garage.
#289 MattD
MattD
  • 3,561 posts
Posted 02 June 2020 - 09:58 AM
Jump in Eddie.  Between Steve and few other guys here, you can get guidance all the way thru.     I even saw that a guy with a 3D printer on another forum downloaded a program from "thingieverse" that is a router template that works like the one  Steve has made on this thread.    Pre-taped braid makes makes braiding  as easy as it can be.
Router bits are available to cut the gains for the braid using the 1/8 inch center pilot.
 It's more about your desire to build and that you will stick with it, than it is about the skills needed.   A simple 4X8 sheet of MDF and just building a two lane flat oval will quickly  teach you how to cut the slots, braid and wire and then you will know if you really want to build a bigger multi lane track.
  • Pappy, Chris Dadds, Eddie Fleming and 2 others like this
#290 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 03 June 2020 - 07:56 AM
Here is a link to a club track in Edmonton Alberta Canada. I was looking for tracks in Alberta and this is the only one I found doing a search. This was Ogilvie Custom Tracks # 594, a 4 lane Grandstand built by Brian Crosby.
Edmonton Slot Car Club
  • Eddie Fleming and William Bowden like this
#291 MattD
MattD
  • 3,561 posts
Posted 03 June 2020 - 09:05 AM
Steve on the new track what kind of tires are you running and how is the grip?
#292 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 03 June 2020 - 11:34 AM
Right now we are using fish tires that are new old stock. As long as I keep the track clean( I wipe it down with a tack rag before use) and clean the tires often we can actually run on high power but the grip is not the best. Part of that is the cars need some more work but we can have fun on a lower power setting. I am trying to avoid using spray glue if I can but the cars are not laying down any rubber the way we are running now. I was expecting to see some wear on the tires but they still look like new.
I am going to look in to silicone tires, I think they would work well. I am going through my inventory of stuff and the only thing I do not have new are guide flags. So when I order them in I will get 4 sets of silicones to try out.
#293 MattD
MattD
  • 3,561 posts
Posted 03 June 2020 - 12:37 PM
I'll send you a set of silicone coated tires to try.
#294 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 03 June 2020 - 08:16 PM
Thanks Matt. I ended up mixing some weakish spray glue for now. It works great, the cars are handling really well now. With an admittedly weak battery(no one bothered to plug in the charger for 3 days), on high power you can punch the bank on the outside 2 lanes and punch the donut on the two outside lanes of the donut. It is a fast track. That is with a challenger 1 motor in a champion flexi chassis. Still waiting on my pin striper and power supply and lap counter. Nothing gets here fast these days.
#295 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 03 June 2020 - 08:45 PM
(12) Steve Ogilvie Builds a Track - YouTube
  • slotbaker, Eddie Fleming, William Bowden and 1 other like this
#296 NateT
NateT
  • 232 posts
Posted 04 June 2020 - 11:08 AM
Hi Steve,
If you ever need any parts and dont feel like ordering, just let me know.  We have most basic stuff in London and my Inlaws are in Kincardine.
I would be more than happy to help out when I can.
  • William Bowden and Tomark like this
Nate Talaskavich
NateTalaskavich@gmail.com
Track Owner at ONO Raceway in London Ontario
 ONO Slot car club Facebook page
#297 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 04 June 2020 - 12:58 PM
Thanks Nate actually I was thinking about going down to Ono hopefully sooner than later. Right now my basement is kind of a slot car wrecking yard as I sort through all the stuff I have in boxes.
#298 Gak
Gak
  • 13 posts
Posted 05 June 2020 - 05:06 PM
Hi all again, Hope you folks dont mind me asking a tech question.
I've made a Router jig like yours, for the slots, all cuts are good Im very happy with its performance, but....
on my corner test piece I have a
6"/152mm gutter, and I recall you saying about as you cut tighter from outer lane 1 to inner lane 4, the distance/width changes.
outer lane 1 to 2 distance is 4-9/32 or 109mm
Lane 2 to 3 is 4-5/16 or 110mm
inner Lanes 3 to 4  4-3/8 or 113mm
Does this make much difference if this irregular width is used on whole track, as in will it even out over the distance on a figure 8 track or
would it be better to have 2 or 3 pin settings in the router jig to compensate to keep lane distances exact?
Any advice would be most helpful
Graham Bowden
#299 MattD
MattD
  • 3,561 posts
Posted 05 June 2020 - 06:29 PM
Just don't tell anybody.
  • Steve Ogilvie, William Bowden and Gak like this
#300 MSwiss
  • 25,928 posts
Posted 05 June 2020 - 06:51 PM
I've never understood why people are worried about equal lap lengths.
All computer programs have all racers racing on all lanes.
  • Tim Neja, William Bowden and Gak like this
