How to build slot car tracks
405 replies to this topic
#126 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 18 April 2020 - 06:19 PM
Spent most of the day building more sections and cutting leg and sidewall brackets. I ran out of sawhorses to stack sections on but got a couple more from Dan for tomorrow. The  shed is full of sawdust now, pretty much wearing my respirator mask full time when I am in there now. Only the 8' bank turn and the 2 straights that lead in to it left to assemble now.
   When I attach the leg supports, I do not glue the entire bottom of the L bracket:
This allows the track surface to flex without making flat spots in a banked curve or a twisted straight, such as the straight  going from the bank to the deadman on a king track.
The completed large piece of the donut.
The rest of the donut:
Here is a pic of the glued joint on one of the bridge pieces.
Once I have the other pieces assembled and stacked up, I can start putting legs together and standing the track up. I have about half the triangles I need cut out now.
  • Rob Voska, MattD, William Bowden and 1 other like this
#127 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 19 April 2020 - 05:20 PM
All the track pieces are assembled now and ready for legs.
After I took this picture, I rearranged all the pieces in to 2 piles and made a spot up near the big door to cut legs and put them together. That will take up most of tomorrow.
  • William Bowden likes this
#128 MattD
MattD
  • 3,561 posts
Posted 19 April 2020 - 08:23 PM
I think this guy knows what he is doing.   It looks so nice, I with I had the patience to do work like that.  I'd be afraid for you guys to see what my track looks like underneath!
  • Steve Ogilvie and William Bowden like this
#129 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 19 April 2020 - 09:20 PM
If a track looks good on top, nobody looks underneath lol.
#130 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 20 April 2020 - 02:44 PM
Today I made some more legs and put some slots in half of them. Used the dado blade set for just a bit wider than 1/4". First I ripped a sheet of mdf into 3 -16" wide pieces and stacked them. Marked out the triangles and cut 3 at a time with the circular saw. Then dado'd the slots by using the push guide, holding them where I needed and dropping the triangle on to the blade.
I might be a couple of legs short but I still have more mdf if I need to cut more. With the dado up as high as it goes, just dropping down on the blade holding it with the push guide creates a long enough slot.
I did not have any 1/4" bolts so I waited 2 hours for Canadian Tire to get back to me and they never did. I forgot the local Rona building centre stocks bolts in bulk so I got what I needed there for 1/3 of the price of Can Tire. You have to call in all orders and then wait outside the store for them to bring it out to you.
  • rvec, William Bowden and Racer36 like this
#131 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 20 April 2020 - 05:33 PM
All the legs are made now. Made up a quick jig out of some scrap and put the legs together.
  • Tex, Lou E, William Bowden and 2 others like this
#132 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 21 April 2020 - 05:34 PM
I was really hoping to get some track sections stood up and joined together today but it was below freezing for most of the day. And no sunshine so too cold to glue anything in the shed today. Put 2 videos on Youtube. The first one is the start of cutting out the track. Very short, just figuring out the Gopro. I have about 6 more made with the Gopro to upload. Hopefully better than this one. But it's a start.
GOPR0052 - YouTube
This one is a walk around the shop showing where progress is so far, and a bit about me.
IMG 2902 1 - YouTube
  • Zippity, Lou E, Rob Voska and 3 others like this
#133 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 22 April 2020 - 08:22 AM
Another short video.     Steve Ogilvie builds a track 3 - YouTube
Another cold and snowy morning here. Going to go out and clean up the shed and make some support pieces to use for trimming and holding up the joint blocks for attachment to the track pieces. Supposed to be sunny this afternoon so I should be able to do some gluing.
  • Zippity, Rob Voska, MattD and 2 others like this
#134 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 22 April 2020 - 06:21 PM
Got a lot done but no joints connected yet. Took a long time to clean up the sawdust, bolt the legs on and  I thought I could put the 8' bank turn up by the boat but that was a no go so I had to move all the pieces again. But it was great to finally see something that looks like a track out there.
  • Pappy, Tim Neja, Lou E and 5 others like this
#135 MattD
MattD
  • 3,561 posts
Posted 22 April 2020 - 11:28 PM
Really sanitary Steve.
  • Steve Ogilvie likes this
#136 Zippity
Zippity
  • 5,278 posts
Posted 23 April 2020 - 01:42 AM
Keep those videos coming :)
  • Steve Ogilvie, William Bowden and Gak like this
Ron Thornton
#137 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 23 April 2020 - 09:06 AM
Thanks for all the comments and the Likes. Another video, this one is getting the joints ready for bolts.
Steve Ogilvie builds a Track 4 - YouTube
  • Zippity, William Bowden and Dale Tomczyk like this
#138 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 23 April 2020 - 04:50 PM
Another walk around video    Steve Ogilvie builds a slot car track.Walk around 2. - YouTube
#139 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 23 April 2020 - 05:44 PM
Made a lot of progress today. Trimmed all the rough edges today. Cut the slot in the joint blocks. And made up a bunch of wooden washers.
Glued and clamped joint block to a track section
My clamps are 1/4" mdf cut in to squares with a 2" long #8 deck screw and a washer. Note the glue oozing out  under the track surface. After about 2 minutes the exposed glue is about  the same size from one side of the joint to the other side.. The washer screws give lots of clamping force. I wait about 10 minutes for the glue to get a little gummy and scrape it off with a putty knife.
  • Rob Voska, Eddie Fleming and William Bowden like this
#140 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 23 April 2020 - 05:51 PM
Test fit:
Taped one side of the joint block to the tongue and oiled the part that I don't want to stick together.
Getting cool in the shed so thats it for today.
#141 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 24 April 2020 - 07:11 AM
Normally when I attach the joint blocks to a track, I trim the ends and then put the joint on one side and carry on like that around the track. Then go back to the joints that need the excess glue scraped off and oil that joint. But for most of the day yesterday it was too cold for gluing. Today it should be nice enough in the shed for gluing so I should have  everything glued together except the overbridge.
#142 MattD
MattD
  • 3,561 posts
Posted 24 April 2020 - 08:08 AM
https://www.ebay.com...984.m1436.l2649
Remember this one?
#143 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 24 April 2020 - 09:08 AM
We built quite a few Orange style tracks like that one. Looks like that one was never leveled to the floor it is sitting on. Note the crooked leg under the donut and the hump right over the joint in the straightaway. Not hard to adjust the legs to fix that. And add a brace to stiffen up the driver panel area. Over the years when I visited some of our older tracks I noticed how people put weight on that area either putting a foot up while running a car or just using the sidewall to help themselves out of a chair. Some angle braces or posts made out of 2x4's solves that problem. Don't know the history of that track though sorry.
#144 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 24 April 2020 - 09:11 AM
Another video, bolting the joint blocks together. This one should have been #5 my bad. Tried to edit it but couldn't figure it out.
Steve Ogilvie builds a track 4 - YouTube
  • Zippity, Rob Voska, MattD and 1 other like this
#145 MattD
MattD
  • 3,561 posts
Posted 24 April 2020 - 01:51 PM
Steve,  it's nice to see all the steps and details.     Makes me want to build another track, almost!
  • Steve Ogilvie, William Bowden and Tomark like this
#146 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 24 April 2020 - 04:21 PM
After building this track in a relatively small space I have a lot of respect for guys like you that manage to do it in their basement. I can not imagine dealing with this dust in the house.
#147 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 24 April 2020 - 05:49 PM
All the joint blocks are attached now and all the track sections that can be routed at the same time are together.
All that has to be filled are 10 1/8" holes. I use polyfilla to fill the holes. So much less work than filling screw heads.
This is where it is at now:
  • Zippity, Dominator, Eddie Fleming and 2 others like this
#148 MattD
MattD
  • 3,561 posts
Posted 24 April 2020 - 07:44 PM
Steve I had an advantage in that I didn't know what I was doing.    I routed a 4 X 8 four lane 90 degree curve in my carport and had my fan blowing saw dust away.   I cut two 8 foot straight and connected one at each side of the corner, as you had told me.  I then tightened the straps and pulled the bank.   I knew then I could build a pretty simple track with smooth banked corners.   I went ahead and routed two more 90 degree curves.   Next I cut the straight tracks and routed them.   Everything at 4 inch centers and 6 on the outside.    I then hauled all this mdf down to the garage I share with my brother.  I had an 8 foot by 30 foot table there for Carrera track.  I removed the Carrera and then built my track on this table,  At this time it had only the 1/8 main slot.   I cut the mdf and put it together like you would sectional track.  Used blocks to create the banks as I wanted them on the table top.    Once I had it together and banked as I wanted, it was complete and setting on this table,.   I raised it 18? inches all the way around and installed the legs.   I now had the track surface and legs  done, banked and all pieces together..But I had a track mostly complete, but it was on this table!    I thought of dismantling it and  removing the table, but it was so smooth, I hated  to take it apart.   what I did was separate it into halves.  I built a truss under each half and lifted it with my engine hoist and cut the table out from under it, then lowered it to the floor and put both halves back together.   Routed the braid relief with a bit from Slot Car Corner and held my vac there to catch the dust.
Painted, built sidewalls and wired it.   Eventually replaced the flat end of the track with a section of 5 inch wide lanes instead of 4 inches.   Still had a ton of sawdust and used the leaf blower to blow out the garage every day or two.
I enjoyed doing it, completely by myself, and spent a few weeks jacking it up here and there and laying bags of rock salt on it to  change some banking and twisting.
I did end up using screws and kind of forgot the nail gun.    I built legs that had a cross brace at the bottom and once elevation was where I wanted it I tightened them to hold that position.   It made it very strong.
#149 MattD
MattD
  • 3,561 posts
Posted 24 April 2020 - 10:55 PM
Oh yeah, Steve. I appreciate all the advice I got from you when I was doing it
#150 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 25 April 2020 - 08:57 AM
Thanks Matt. Trying to catch up on my videos, here is part 1 of putting the top plates on the joint blocks.
Steve Ogilvie builds a track 6 - YouTube
