453 replies to this topic
#101 Ramcatlarry
  • 2,944 posts
Posted 16 April 2020 - 09:26 AM
GAME ON
#102 Howie Ursaner
Howie Ursaner
  • 1,452 posts
Posted 16 April 2020 - 09:48 AM
You don't use the Kemtron motor. You use the Kemtron magnet and stacks only , you cut the lams down. You use a Ram 4v
armature Pittman 85 brushes and make the rails carry the bearings.  I think Braverman might have used Different brush setup,for the LIndsay.not sure but it would be easy to use big dc 85 brushes also.This stuff went crazy on 36 volts. Thats where all the excitement was.
For Brakes, you have the shutoff area shorted out so the motor stops the car as well as glue.
  • Alan Draht likes this
Howie Ursaner
#103 Dave Crevie
  • 4,529 posts
Posted 16 April 2020 - 11:34 AM
I recall that some guys were using the thin Kemtron lams. I don't remember that their magnets were better, but if you say it, I accept it. The thin lams were easier
to shape, and I believe produced a better field. I certainly wasn't in with the "elite" racers, so most of what I did was by trial and error. (like most everyone else)
Everyone I knew was using the silver Pittman style brushes.
My local dragstrip had a relatively short shut down, and tee'd into a brick wall. If your car scooted under the parachute, it was toast. I started taping the lead edge
of the 'chute to the track with black plastic electrical tape to help make sure the car went into the 'chute.
#104 TSR
  • 42,299 posts
Posted 16 April 2020 - 07:11 PM
Last of Husting's killer racers, the car that set a record not bettered for 21 years. The motor is made from a Buick windshield wiper motor's circular magnet with a Ram armature blank wound by Gene. 0.93" to the "quarter" if I recall.
  • hiline2, Howie Ursaner, Geary Carrier and 1 other like this
#105 Dave Crevie
  • 4,529 posts
Posted 17 April 2020 - 09:04 AM
Real car parts had a way of finding their way into slot dragsters. I have an arm from a window winder motor that I had planned on using in a direct-drive magwinder.
It was a good bit bigger in diameter than a padlock arm. For s**ts and giggles I might finish that car. I'm not at home right now but later I will dig it out and post some pics.
I like the statement on the plaque that says there were 60 slot tracks in SoCal. Only 60? You couldn't sling a dead cat back then and not hit a slot track!
#106 don.siegel
  • 5,851 posts
Posted 17 April 2020 - 01:12 PM
Speaking of real-car or other magnets, anybody recognize this one?
  • hiline2 likes this
#107 TSR
  • 42,299 posts
Posted 17 April 2020 - 05:31 PM
Don,
looks like a modified Lindsay but the pictures are too dark to be sure.
  • Howie Ursaner likes this
#108 Tom Katsanis
Tom Katsanis
  • 376 posts
Posted 18 April 2020 - 01:03 AM
Is it a circular magnet or a horseshoe Lindsay were horseshoe Athens Jet are circular in slot car motors they may be the only ones I have never pulled down a Wilson I'm not sure if there circular besides that it could come from anywhere like Hustings Buick wiper magnet.
#109 don.siegel
  • 5,851 posts
Posted 18 April 2020 - 04:01 AM
It's circular - I'll try to get a better picture up... arm is just a regular Ram if I remember right.
  • Tom Katsanis likes this
#110 hiline2
hiline2
  • 468 posts
Posted 19 April 2020 - 07:11 AM
Just to refresh memories of past proxy racing !
http://slotblog.net/...nspection-line/
Paul Bass
#111 Alan Draht
Alan Draht
  • 812 posts
Posted 19 April 2020 - 09:25 PM
I looked at this.  I had no idea...
#112 boxerdog
boxerdog
  • 877 posts
Posted 20 April 2020 - 09:13 AM
It was fun at that time...
David Cummerow
#113 Alan Draht
Alan Draht
  • 812 posts
Posted 22 April 2020 - 02:09 PM
In case anyone's interested, I found NOS 1960's Graupner Record-Elastik 40mm tall x 14mm wide model airplane tires.
These will be mounted onto vintage Russkit dragster wheels for my Husting replica dragster for sure, and probably the Maldonado replica, too.
These were the tires that I had on my Pittman-powered aluminum channel chassis that I talked about in the other thread ("Re-creating Howie's rocketship").  I'll bet they were on Howie's car, too.  Graupner model plane tires were what the mid-1960's slot car race pro's used, at least in the NYC area.
Polk's Hobbies' slot car racers used to buy them in the model planes department on the second or third floor of Polk's 5th Avenue building.  They were piled up in a large box or barrel set on the floor.  We'd go downstairs and squeeze the Graupner tires until we found a pair soft/ hard enough for our purposes before we bought them.
  • hiline2, Howie Ursaner, Tom Katsanis and 1 other like this
#114 Alan Draht
Alan Draht
  • 812 posts
Posted 22 April 2020 - 02:13 PM
Here's the link:
https://www.ebay.com...ikAAOSwTA9X3vnb
Please note:  I am not affiliated with or working on behalf of eBay or this eBay seller.
#115 Phloidboy1
Phloidboy1
    PHLOIDBOY
  • 66 posts
Posted 23 April 2020 - 11:15 PM
GENE HUSTING REPLICA  CONTRUCTED 2018 BUILT AS SPECIFICATIONS REQUIRED IN 4 PART SERIES IN ROD AND CUSTUM MAGAZINE DEC '65 THRU MAR '66
  • hiline2, MSwiss, Uncle Fred and 6 others like this
Floyd Hornbaker
#116 Geary Carrier
Geary Carrier
  • 614 posts
Posted 23 April 2020 - 11:19 PM
:good:
  • Phloidboy1 likes this
#117 Dave Crevie
  • 4,529 posts
Posted 24 April 2020 - 09:00 AM
Nicely done.
#118 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 01:56 PM
I've been working on my Gene Husting Rod & Custom replica.  This is a scratch-built project that requires a fair amount of machining.  I've made some progress.
  • hiline2, MSwiss, Howie Ursaner and 2 others like this
#119 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:18 PM
  • MSwiss, Geary Carrier, Tom Katsanis and 1 other like this
#120 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:21 PM
  • hiline2 and Geary Carrier like this
#121 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:24 PM
#122 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:28 PM
  • hiline2, Geary Carrier and Phloidboy1 like this
#123 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:30 PM
#124 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:32 PM
  • hiline2, MSwiss, Howie Ursaner and 4 others like this
#125 Alan Draht
Alan Draht
  • 812 posts
Posted 29 April 2020 - 02:35 PM
The next step is to draw/ scribe outlines of the outside form and the inside opening shapes of Husting's magnesium left and right frame plates.
  • hiline2, MSwiss and Phloidboy1 like this
